Re: compression 50 psi all cylinders, 88 v4, 140 hp
I have the same exact engine. 1988 looper V4 140hp, the one is on my avatar. When I first got it 3 years ago, boat was parked for 2 years, compression was under 60 psi on two cyl (starboard side). I ran the engine with one can of seafoam mixed with one gallon of gas, spray some seafoam deep creep thru the spark plug holes with the engine hot and problem was solved. Recheck compression and readings was 120 psi on all four cyl. Now I do this every 3-4 months and my engine runs perfect.
