Re: Battery goes dead
Check for any draw on the battery when the ignition is OFF. Make sure you pull the key when in storage to make sure you are OFF and not on ACC. If no drain, key OFF, you problem is the battery. If there is a drain you have 2 choices, live with it and disconnect the battery when in storage, OR find the drain. The second option would be the best, but could also be very time consuming.
