Best Anti Fowling products for North East??
novie
buying a 2004 Sea Hunt Triton that does not have any finish (has been waxed)
and wondering if I should put a barrier system on the bottom or just anti fowling
paint.
Would appreciate any comments from power boaters out there. She will be sitting
on a mooring in Salt Water when not in use from June to mid Sept.
Would you put a barrier system and anti fowling, your experiences pls
DBreskin
Re: Best Anti Fowling products for North East??
Welcome to iBoats.
I find a good hunting dog will keep away the birds. <grin>
I'm not qualified to comment on anti-fouling materials.
Texasmark
Interlux (brand) Marine Coatings have been around for 50 years that I know of. Might tweak them.
Mark
JoLin
Hi, and welcome to iboats!
Barrier (double) coat, definitely, to seal the gelcoat and help prevent blister formation. Follow that up with 2-3 coats of anti-fouling. A common method (at least for ablative coatings) is to do the first coat in one color, and subsequent coats in a different color. That way you know when the coating is getting worn away.
I'd poll boaters in your area for anti-fouling recommendations. Every region seems to have a different growth problem (here it's barnacles) and I've never seen a consensus on a paint that works 'everywhere'.
My .02
ken51k
JoLins' comment is right on, but I'd like to add that you want to make sure you remove all the wax and give the gelcoat a light sanding
before you apply the berrier coats. Liquid dish shoap works pretty good.
Home Cookin'
I have a 2004 sea hunt triton, too (21') great boat; you'll love it! check out the seashunt owners forum.
I keep mine moored in salt water year round.
I bought mine used with a virgin bottom. I use the inerlux micron ablative. I got a boat yard to apply the primer (barrier) and then paint 2 coats. I repaint every 2 years or so. I haul it (trailer) about every 3 months to clean the bottom; the growth gets on the transom and waerline, since that is out of the water on a plane (ablative paint basically sheds what grows on it).
You will use a different primer/paint for your metal parts: trim tabs, ladder brace, bottom corner of motor, etc. They are all unreasonably expensive and none of them work. Just saying.
JoLin
LOL- ain't that the truth. A favorite(?) pasttime at our summer raftups is for several of us to get into the water with scrapers and go from boat to boat scraping barnacles off the props, I/O legs and trim tabs.
tpenfield
paint.
Welcome to iBoats . . .
Anti-fouling (fowling is for the birds)
Since you will be in salt water for a while each year . . . yes, go with the barrier coat. And then go with high-end Pettit or similar brand ablative i.e., the expensive stuff. In my experience, I have used Pettit copper ablative on my sailboat, but on my powerboats, I have used ePaint EP-2000 with excellent results.
