Mercury 35hp problem
mustang72
hi im new here and i come for your help because i heard here are the best outboard mechanics ;)
so i recently bought 2 mercury outboards ( estimate 70-80s models)
but i have a problem :eek:
i cant find a way to start them as they did not come with any controllers.
so my question is:: Is there any way to jumpstart it? also can you tell me what are the sockets for in the picture attached?( saying as what do you connect to each one) thanks for your help :)
carholme
Re: Mercury 35hp problem
Why don't you provide the s/ns for the engines and we can provide you with the wiring diagrams.
Gerry
M
Maxz695
Guest
You don,t need to hook anything up to that plug to try to start the engine You will need to either cross the solenoid to jump start the starter. but you will have to have a battery hooked up properly to the engine or you will mess up the charging system and maybe more. Here is a picture of my remote starter switch I hooked up. The big terminal where the starter hooks to and the little yellow wire with the red stripe are where they are connected and those are the terminals to cross to engage the starter. You can also try pull starting the engine with a rope. Again do not start the engine without a battery connected to it. Fair warning. View attachment 178395 Here is a pic of my 40 HP with the other type solenoid View attachment 178396
mustang72
thanks for the quick answers much appreciated ;) i will try to start it this week (hopefully)
and here is the pic of the serial number (i think it this) its not very clear but its read able it reads 09613611
joed
You didn't say how to stop it after it starts. Do you have a kill switch installed somewhere, or do you just pull the gas line off?
M
Maxz695
Guest
choke it to stop it. pulling the fuel line will also stop it after it runs out of fuel. There should be a manual choke on it
mustang72
just pull the fuel line out i think its safe as i have seen it on many videos on youtube and this thing being done to my evinrude 115 v4 when it was serviced. also i have flush muffs so im safe to do it( i think so :lol:)
carholme
http://download.brunswick-marine.com/download/dosearch/@isnew/desc?mod=17&lang=EN&categories=Outboard$
If you click on the link and open the European pdf, scroll down to 1990 35s, you will see that 1990 begins with s/n 9586000 and 1991 begins with 9630000. Therefore as yours is less than 9630000, it would be a 1990 engine made in Belgium.
Parts List:
Mercury Parts, 35 H.P.
Service Manual P/N: 90-42794--1
1990 Mercury Outboard 35 40 HP Factory Service Manual | eBay
Gerry
mustang72
thanks for your help guys much appreciated
another question now comes to my mind what is the 8-pin connector for??
carholme
That should be the female end of the engine internal wiring harness which connects to the harness coming from the remote control.
See the harness as item 12 under STARTER MOTOR, RECTIFIER AND WIRING HARNESS (ELECTRIC) in the parts listing above.
Gerry
