Hello again to everyone. Football season is over, so I finally have some time to work on my rebuild project. This motor was given to me by family, so I know its history....sort of. This is going to be a fairly long post, but I will try to make it halfway readable.
This motor sat for about three years. A buddy of mine had the exact same motor, but he blew up the powerhead after installing several new parts. He gave me the old motor to salvage. So far I have:
1. Replaced Impeller- Changed lower unit oil- Pressure tested good.
2. Replaced Poppet Valve and Thermostat
3. Replaced Stator and Trigger (off salvage motor- recently new)
4. Replaced Switch Pack (off salvage motor- Brand new)
5. New Plugs of course
6. Cleaned and Rebuilt Carbs ( DID NOT SOAK CARBS...I know, I should have)
7. New INLINE Filter- (Running fresh gas from remote tank)
Compression Test: 117-117-115
Motor did fire up, but it idles rough as hell. It will "POP" and smoke like crazy. It will fire back up, but only after pumping up the ball which gets soft during this time....which is leading me to believe I have a fuel issue. Getting good spark on all three coils.
My questions are:
A. What about the fuel pump? Do I need to rebuild or replace this thing?
B. I have read so much about setting timing, but I am confused as hell. I replaced Stator and Trigger which required pulling the flywheel, but I have no idea if I need to do something else before starting.
C. Do I need to remove carbs again and soak them to remove hidden gunk?
I feel like I have a fairly solid motor, and I am on the verge of getting this thing right. But I am sort of agrivated right now. Where should I go from this point?
Appreciate the help. GO IRISH Tomorrow night!
My questions are:
