Trying to figure out if I need to replace my leaf springs and spindles- pictures!
massimofinance
Hi all, I removed my rims and tires. Replacing the bearings, races, seals. Can anyone tell me what I need to do about the leaf springs? I would think they need replacing, but like an opinion here. also what about the spindles? Happy to replace as well, but I am not sure how to do it, etrailers does not have a video. Thanks...
trailer 2.jpgtrailer 1.jpgtrailer 3.jpgtrailer 2.jpgtrailer 1.jpgtrailer 3.jpg
massimofinance
Re: Trying to figure out if I need to replace my leaf springs and spindles- pictures!
Sorry the pictures are up side down!
UncleWillie
...I am not sure how to do it, etrailers does not have a video...
Spindles are commonly welded to the axle and the axle is replaced as an entire assemble.
If your spindles are replaceable; unbolt the old one and remount the new one.
Yours do not look replaceable.
Rusty leaf springs are not necessarily bad, cleaning off the rust and adding some paint will make them look nicer.
Both jobs are simple unbolt and replace items.
Bob_VT
I would clean everything with a wire brush. Before you replace anything the rust needs to be removed and a careful inspection of the spindles for wear. It just looks to me like it was parked in the grass and neglected and could be salvageable
Mi duckdown
If I'm not mistaken, it looks like you also have the inside part of the inner bearing stuck on the spindle?
massimofinance
Thanks everyone- MI DuckDown, you are correct, I snapped the pics before I removed the inner bearing (or what was left of it!). I m going to clean it all up and just do the bearings in that case, unless I hear something else. Love to know the tell tale signs for when to replace leaf springs and spindles, if anyone has a tip...
massimofinance
NYBo
That brake mounting flange looks pretty ugly. Better check how deep that rust is.
Mi duckdown
If it was mine I price would check the price, for New. then go from there. Those backing plates,TO me are FUBAR. Somtimes it easier To write a check,and Less costly. .02
massimofinance
Thanks- price for new for the entire trailer ? Or just the axles? I looked online and it does not seem they sell the entire axle. Also, is it possible to replace the axles with the boat on the trailer? Thx.
bonz_d
Of course it is possible, Just remember to put some sturdy jack stands under it so it cannot move. Still safer to do empty/
massimofinance
Thanks Uncle Willie! I am taking a steel brush to the rust this weekend and will evaluate from there.
