Approximately where is the water pump?s drain hole on a 1970 35HP Chrysler? Noticing a post last week, I knew I probably d/n drop my engine completely as in the past (thinking we were going fishing again). With the motor on the transom saver and tilt of the boat I feel it should be OK after the extended freezing weather in the North Tx DFW area. I feel any water should have drained or evaporated from the summer?s heat since May, 2012. A quick ext check d/n show any signs of damage (bulging or cracks).
Attachments will show it was close to down and hopefully the drain hole is to the right of the shaft close to down.
