Allwaters
- Oct 4, 2012
- 15
Hi all... headed to harborchandler in the morning to pick up a few things for my project. I was going to rely on the advice of the guys at the store as they seem to be quite knowledgable, but i thought I'd post on here aswell.I just popped the old lovely evinrude ficht off the back of my boat and am putting a new yamaha on in a month or so. Now there are holes from the boats original motor that are plugged with bolts and sealant, i have removed the bolts and plan to repair these. I also feel i have to repair the recent motors mounting holes because the new yamaha will not have the same bolt configuration? I was wondering what would be the best product to repair these holes.. I was thinking a shortened woooden dowel glued in but leave enough room for an epoxy filler on both sides? I also some small dings in the bottom of the hull and some large scrapes in the gel coat on the one side would the same product work on these?
Now the plan after all the holes are repaired is to paint the hull and all the way up to the rubber bumber which surrounds the boat. I have to remove the decals for this to be done... is there any good products to remove these rather than sanding?
Last will be the painting. I was planning on going with a dark tophy green to just above the water line than white or cream for the top. The bottom has some antifouling that needs to be removed i have tried the pressure washer in a few spots with not much luck so it looks like i will be sanding the stuff off.... yay. Now my question for painting over the gelcoat is...Do i have to rough it up first? I know i have to wash it free of wax and other things. Is priming necessarry? what do you think of interlux paints?
Alot of questions... will post pics as it progresses
