Tugcaptain
- Dec 29, 2012
- 2
I have a 32' yukon delta that I have stripped to the hull, and a Cummins 4bta, with a borg warner 72c clutch. So far I have replaced the transom, and starting on a new stringer design to adopt the Cummins/clutch. Atter the stringers are installed, i am going to install the rudder and packing assy for it, then the shaft strut/cutlass bearing assy, and thru hull shaft log packing assy., and install the shaft. I am by no means a hydraulic engineer. I have access to several shaft logs, and struts of different angles of degree, and I'll be using a 17" prop to make up for the 1/1 ratio of the clutch and slow engine speed. My question is how much angle is too much. I want to swing as big a wheel as possible, with a 1" shaft.
