Thriller1980
- Jan 2, 2013
- 6
Hello to all of you. I love this forum, this is my first post, I don't think this has been asked before but I I won't be surprised if it has. I am rebuilding my 95 Johnson 90 hp 60 degree looper due to a low compression in #4 cylinder. Things I have found wrong with it since closer inspection are, a missing roller sleeve on starboard throttle body cam affecting link and sync, 4 leaking float bowls (fixed), 1 cylinder was running hotter than the other, compression 128-132-125-82. Different rtv colours on heads (alarm bells), cracked crankcase cover at alignment taper pin, crank bearings spun a little due to dowel pins not aligned on last assembly, corrosion on cylinder head especially at the thermostat interface and at the exhaust port to head on #4 bore hence the low compression and a few other minors.
My question to you is how do I align my crankcase and cover with crack at taper pin hole in the cover and what is the part number for the check valve located under the crank split bearing halves? The stainless button from the valve manage to get lodged between the case and the bearing halve! Quite a sight to see, I didn't expect my rebuild to have so many obstacles.
One more question is forged or cast?
Thanks everyone who offers advice.
