Hello All, I'm new to this forum having recently purchased my first boat. I'm not sure if you can help me but I have a technical question regarding my '85 Evinrude 45 Super, E45RSZ.
Prior to having some recent work done to the water pump, I was experiencing that after running the outboard for 15 or 20 minutes, then shutting it off for a while it was reluctant to restart without re-choking the engine and a few pumps of the primer bulb. So, just before Christmas I took it to a reputable Evinrude mechanic to have the impeller replaced and on his advice he rebuilt the pump.
The mechanic suggested when I collected it that the motor was "running cold" which he thought may have been caused by a missing thermostat. I purchased a new thermostat and gaskets from him and installed it myself even though I discovered that there was a thermostat and it was working correctly. I thanked him, paid the money (which was my grocery money for the fortnight plus some) and over the holidays went to put my boat in the water only to find that no water was flowing out of the telltale. So much for my holiday plans of getting out on the water here in Australia.
Today I took it back to the mechanic who carried out the work. He removed the lower unit and tested the rebuilt pump, which seems to be working fine. He also placed a hose up the water tube to see if water was circulating through the power head without the lower unit in place, which it is.
The problem seems to be that when the lower unit installed no water is reaching the power head. I'm just wondering if anyone might be able to suggest where he (and I) should be looking in order to try and rectify whatever fault is causing this problem as he is at a loss to explain why this is happening and now we are both left scratching our heads. I appreciate that the outboard is old, but it's all I can afford and I don't have alot of money to throw at it.
Any input would be greatly appreciated
