Cricket Too
- May 14, 2003
- 1,732
First year with this engine and I've been looking around the site at old posts about EFI fogging. It seems as though spraying fogging oil through the intake isn't a good idea due to sensors, although I don't see any sensors that would be in my intake, plus taking the cover off involves 12 allen bolts and looks like the VST has to come off as well, so it's a pain to do it seems.
I know the pull the plugs and spray fogging oil down the cylinders and give a few cranks method, but that won't do much for coating the internals (crank, rods) with fogging oil. When I first got my old Ficht I was told the best way to fog was to pull the internal fuel/water separator and dump out 1/2 the fuel and fill with fogging oil, put it back on and run it to suck the fogging oil in, but that always seemed like it burned it off way too quick to do anything. The Ficht was easier to get at the front to spray oil through the intake than this Merc (250 EFI), so I was thinking about trying the internal fuel/water separator trick, but still not sure that does anything.
Anyway just looking for suggestions on fogging this type of motor from anyone who has one or knows them. Also what is the consensus on draining the VST for the winter, seems like it's a good idea to not leave fuel sitting in it for 4 months.
Thanks.
Thanks.
