Crestliner nordic 18 rub rail
Rmoran171
Ive searched high and low for run rail For my crestliner Nordic 18 and cant find any that even closely matches the factory rub rail. Does anyone know if anyone makes it? Ive checked Taco marine, Iboats, some other different places with no luck. I only need the rub rail to finish my total restoration of my Nordic. Help would be greatly appreciated.
Woodonglass
Re: Crestliner nordic 18 rub rail
Welcome to iBoats!
Can you post a cross section pic of it? Are you needing the Rubber insert or the actual Aluminum rail?
jbcurt00
You might post a pix of the rubrail, in cross section, and the aluminum channel it needs to fit....
You only need the vinyl insert that fits the aluminum channel that's already installed on the boat, correct?
I suspect you need to find something that's a close match, or will fit. Vintage rubrail is often difficult to match exactly.
Might poke around here, and see what you can find.....
And you might try scanning thru the Crestliner Owner's group threads
Congrats on nearing the end of your project, post some pix of it.
Pix of the project along the way would be great too.............
I think the guys WOG posted will try to match it if you send them a sample.......
