Hi All,
I've recently inherited the old family boat and decided to pull the lower unit off to replace water pump just for piece of mind as I plan to use it a lot and venture 30nm out around the reefs here. It's a nice old motor, starts and runs like new. It's done bugger all hours for its age but found the condition of the lower unit to be not quite in the condition of the top half. The driveshaft was a little rusty and its actually quite pitted around the seal area at the bearing housing underneath the water pump. I wasn't expecting it to be anywhere near that bad of condition as we've always flushed it after use and near dirtied my pants when I saw the price of a new shaft. Has anybody repaired such damage on these shafts in the way of welding and machining back down or sleaving etc? I was always wondering what the difference is between 70973R and the 79R as when searching for parts the 73R is the only model number that comes up for the '79 70hp evinrude. I assume their must be no difference in parts?
Thanks for any advice.
