it cranks up but wont start , wont cycle.i check and change spark-plugs, the new ones got wet so im assuming fuel gets to them but doesnt make combustion, it overheated it couple time the engine, i have issues when i start the motor, i have to push the choke towards the back crank it couple times till it runs, then will day , i pull the choke forward and it will start with the idle all the way up!!! then if i wanna go forward i have to slam the throttle all the way forward so wont kill the motor!!! last time i used it i had to go trough all this and while going back to the marina it stopped , i repeated the moves , it started then died again after 200 yards , did that one more time then it didnt start anymore had to paddle to the shore!!! now it wont start at all !! any if u can make any sense from what i am saying pls help!!!
