I have a 2000 Johnson 50 Hp. It sat for 6 mo. now the trim motor works but the engine won't go up or down. I have opened the filler cap to ad trans fluid. straw berry foam came out I drained as much as I could I refilled. still won't move.
Re: 2000 Johnson 50 Hp motor works won't go up or down
Is the t/t mtr spinning fast or slow ?? You may also want to open up the manual release valve and raise the mtr to full tilt position. And then top off the fluid. Any signs of any leaks ??
