Re: prop question
Pretty much anyone selling props has a prop calculator. I have an 18' 2012 Party Barge with a 75hp Merc. WOT (wide open throttle) is 5500 to 6000 RPM. I experimented with 3 props, 13, 15, and 17 pitch. 15 and 17 pitch would only get me 4000 to 4500 RPM, and the 17 would cavetate. The 13 would turn 4600 RPM and run 24mph (gps). It is all about numbers, the faster the prop spins with the maximum pitch, the faster the boat goes. Too much pitch and the prop won't turn, lugging the motor. Too little pitch, the engine will over rev, or the rev limiters will kick in. Either case, you go slower. 1 change in pitch can / will change your RPM 400 to 600 rpm, give or take.
Good Luck
