Re: Rough running 351 windsor under load at high rpm
Would you beleive two days of scratching my head,,, and lots of, umm, colorful language.
My education came after 5 hours of head scratching while working on a 302 (888).
Idled perfect, sounded smooth as silk, for around 3 minutes then pop and die. I played with the carb adjustment (several times), checked the plug wires and firing order, reset the dwell, re-checked the timing. Run some more and it would pop and die again. After the 3rd time checking the firing order, I found 2 crossed that I didn't see before.
Another customer brought his boat in with the problem the OP has. First thing I did was check the wires (he tuned the boat up). While checking the firing order he told me he check them twice and that wasn't the problem and not to waste my time and his money looking there.
Found the crossed wires, moved them and sent him on his way (no charge) to do the on the water test. Came back smiling a couple hours later and handed me two $20 bills.
He came back quite often for repairs and service.
