Re: Can an impeller vapor lock?
Thanks for all the suggestions guys.......still working on this......to answer your questions:
1) No pee at idle or wot...not even a drop
2) strainers at LU are completely clear
A bit of history in case this helps: Everything was running fine but I had never replaced the impeller and didnt have a telltale (I bought the boat a couple years ago). I opened it up and replaced the impeller (which looked fine btw) and all components in kit (no housing available, but the old one looked ok). Then I installed a telltale right before the t-stat. Took her out and everything went great.....Telltate had a strong stream at idle and at wot.....boat ran great...got up on plane and everything......Then after a few minutes of driving, I shut down at the dock for a little.........I fired it back up and no pisser....not even a drop.....Ran it for a couple minutes anyway, thinking maybe id force some water over the intake at high speed and get things going again, but no luck....no pee still......after a couple minutes got the high temp warning sound and shut down.
My first suspicion is my own work, so back at home I dropped th LU, expecting to see a shot impellor or something that broke, but nothing....Everything was exactly as I left it....Impeller good (not spinning free from spines), key in place, water tube inserted in pickup tube and seal not crushed, strainers clear. More confused than ever.
Thats why Im thinking its something I cant see like air getting in somewhere, or maybe a tiny metal shaving from drilling the telltale hole gumming up the works....I still need to chuck up the shaft with the LU in a bucket and make sure water pumps, but Im not sure how to attach my drill......Still working on it and will keep you posted.
Keep the suggestions coming...I need the pros on this one.......Thanks guys!
