Speakrdude
Ensign
- Feb 25, 2004
- 942
I am in the process of restoring a 93 Maxum Sr2200, with a 454, Bravo 1.
The bilge was a complete botch job by the PO, and I am putting things back in order.
I notice, before we pulled the engine, that one of the power steering hoses that connect to the actuator, was bent so hard it was kinked.
Now that I have things out of the way, I can fix things like this.
(see pic)
#1 These are the hoses, which I am replaceing. Are they supposed to be routed from below? Not much room with the steering cable in front of it.
#2 This large nut is a knuckle type joint that is loose. It looks like it is made to move up and down slightly with the movement of the steering cable. It seems very loose to me but I am not sure how loose it is suppose to be.
I found someone elses pic on another forum. Does this look like the factory routing?
(see picture #2)
Suggestions?
(see pic)
(see picture #2)
Suggestions?
