Re: Help figuring out prepping aluminum boat please!
I would skip the sealer myself, if you are going to rebuck the whole boat it really isn't needed but do the sealer first then the primer, if you go the other way around the primer will block offwhere the seaer should go.
Don't know if you have bucked rivets before but you don't need or want to go nuts on them, 2 decent whacks will seal them and any more than that may actually make them leak.
You should probably get it on some saw horses and get few inches of water in it to see if it even leaks at all, no sense banging on a good boat and possibly making problems.
And with the primer, again assuming you have never used it, it isn't primer in the classic sense like grey primer that covers and fills, etching is mearly a coating as long as you cover everything at all you are good, it doesn't need to be thick.
Good luck and you have a fine holiday also
