Re: 70 vro evinrude motor
Home cookin you are wrong
there is no parts needed to disconnect the vro and go pre-mix, its a very simple process.
if the fuel is now on premix and you suspect the fuel pump has gone bad then do yourself a big favour and
go back to old style fuel pump.
Much cheaper on parts in the future and bullet proof.
The vro style pump is far too expensive to even think about repairing or buying new.
I had a vro pump go bad, infact 2 of them, the price to rebuild is very high and these pumps DO NOT last as
long as the old style before needing to be rebuilt again.
The old style pump with 3 pipes is the one you need, 1 pipe to the pulse 1 from tank and 1 to the carbs.
But like said above it sounds like the carbs are either dirty or need new parts.
And make sure you clean every orifice in the carbs and use all the parts when rebuilding.
good luck
phill
