Hello, ive decided to pull the powerhead off my E70 4stroke to replace what i thought was the sump gasket leaking out beside the top mounts. After removing powerhead and engine carrier ive realised it must be the gasket between powerhead and carrier, not carrier to sump as the oil must of been coming from higher up. Anyhow, its all good as i had both new gaskets and exhaust manifold gasket, im just not sure if i should be using a gasket sealer around these tin/steel pressed gaskets??
last thing i want to do is find it still leaking from a slight warp, but also dont want it to not seal because of the sealer.
Would appreciate some advice from someone who has replaced these type of pressed tin gaskets before, ive only ever dealt with rubber and cork type.
To glue or not to glue???
Thanks
Greg
Thanks
Greg
