Hello all. Need some help. Have a Johnson 2 stroke 1984 75Hp outboard. Installed a telltale and a new impeller (even though the old one looked fine). Fired up the boat and everything looked fine. Telltale squirting and all. All of a sudden the telltale stops pissing and the engine starts to overheat. Intake not blocked. Removed lower end and impeller looks fine nothing loose or missing. My 1st thought was I installed the impeller kit wrong (but why would it work fine for 5 minutes?) No foriegn objects blocking anything. Cant figure out why its not pushing water through anymore? Any areas to check?
Thanks.
Thanks.
