coverting Yamaha 4hp 4stroke to 6hp 4 stroke
ranuplh
If you cant afford to buy another motor like me....try this
yep the motor for the 4, 5 and 6hp 4stroke is the same weight, same bore stroke, same cc of 139.
based on 1hp=25cc then 139cc =5.56hp but most engines are tuned down to a lower HP for better engine life.
Ok what to do
......change the carb from 4hp to 5 or 6 hp equivalent (carb venturi/throat size is the difference between these motors) .
change the exhaust outlet size to the 5 or 6hp one
reset the idle stop adjustment, and verify/adjust full throw of the throttle cable (from idle to WOT)
and thats it.
Rick
boobie
Re: coverting Yamaha 4hp 4stroke to 6hp 4 stroke
What difference is two hp going to do for the performance of the boat for the cost of doing it ??
Capt Ken
Faster trolling speed. Real sleeper outboard. Just think of all those other boats with a 4hsp you can outrun.
ranuplh
Converting Yamaha 4hp 4stroke to 6hp 4 stroke
Well, I'm coming from an engineering approach, rather than a simplistic cost/benefits approach or making fun of small engine four stroke users, when the planet is facing an energy crisis.
To answer your question, it is possible to buy second hand and through understanding the problem solve it.
The 4hp is the underpowered 6hp for the same stroke. The inital torque of both motors is the same, but the output of the 4 to 6hp motor have been limited.
I'd welcome other members who have engine development performance in these small motors.
Capt Ken
Re: Converting Yamaha 4hp 4stroke to 6hp 4 stroke
You have not discovered anything new. Engine builders have been restricting HP on certain engines for decades. It's due to boat builders restricting their boats to certain horsepower. Or they need to compete with a competitors engine. So the question is, is gaining 2 hsp worth the cost of changing the fuel and exhaust system?
