Hello all,
I've got an early 70's, sorry don't have the info handy, Mercury 200 20hp outboard that loses power at high RPMs. I replaced a bad ignition coil a few years back, and cleaned up and re-gapped the points last spring. The engine will start on the second pull, as it always has. It runs well until about 1/2-3/4 throttle, then it kind of sputters in and out. Like its firing one second, then not firing.
I've seen a few threads here that mention the high and low speed coils. Based on what I've read, I'm suspecting the high speed coil. Just looking to see if I'm on the right track with this. Also, can you tell me what the resistance should be for each coil?
Thanks!
Thanks!
