andrewnzinuk
- May 16, 2012
- 21
Hi
Similar issue to a recent post about Tach. Mine is not stuck - it just seems to read to high around WOT. It is a Faria Tach on a Four Winns Horizon 180. I have read a lot about giving them a thump/rap - I also read about moving the switch on the back of the tach between the various positions - from 4, 6, 8 - I assume to clean the points.
I went to the boat had a quick look and cannot see the back of the dashboard when I look up lying underneath the dashboard (i.e cannot see the the guage, when I look up - I see loads of wires).
A few questions :
1) to access the Tach do I need to disconnect all the wiring and unscrew the Dashboard and lift out
2) Assuimg 1 is correct - is there anything I should be especially careful of when disconnecting the wiring?
3) Is it worth worrying about - it reads about 800/1000 rpm too high. I am assuming the engine is fine.
Thanks
Andrew
A few questions :
Thanks
Andrew
