Re: 9.8 Mercury 110 Hard to start
Another thing that could be causing you troubles is the fuel pump on the motor not pumping enought fuel when it is needed. The diaframs will get hard or crack from setting for long periods of time. You will need to test the fuel flow from the pump by disconecting the hose from the carb and placing it in a can or jar and pull the motor over to see if there is a good stream of fuel from the pump. Ethenol in the gas will deterat the older rubber used on several parts of the fuel system. if that fuel has been used, and the motor was not prepared for long time storage. If you do not have a manual for the motor, now would be a good time to invest in one, as it will go into some detail as to the link an sync of the timming and carb linkage setting and is a good investment if you plan on keeping the motor. Bring a motor back to life can sometimes be quite trying and the knowlage learned from doing one will not be forgotten very quickly. The roller on the carb has to be set with the plate just so the timming and carb are in sync for the motor to start and run up in RPM's correctly. When working on the motor ALWAYS have the LU submerged in a barrel of water atleast 5" over the cavation plate if the motor is going to be started and run, as damage to the water pump impeller spining while dry will ruin it very quickly. If the motor runs at a idle and has the older point ing. DO NOT do anything to them, as it takes alot of work to get them set correctly again.JMO
Oldman570
