Flat bottom Everingham
- Dec 18, 2012
- 2
ok well here it goes im in some strife and will start from the begining and see what comes back,
so I have an inboard 350 Chev and pulled the old motor out and have since dropped a completley new one in. however even though ive built a nice new donk from start to finish im stuffed with the wiring and seem to have a short somewhere thats effecting it statrting.;
so whats it doing ?
ok well when i put it all together and started it it would start then run for about 30 seconds then cut out like someone turned the key off. it did this for about 20 starts it stops getting spark to the dizzy then i noticed the brand new electronic dizzy smoking. upon inspection it had burnt out. DAMN dodgy dizzy says me and whacks another in only for it to burn out the remote coil on the new one.
so I add new ignition coil and ignition barrel ... BANG starts first go and runs like a dream. take it for a run runs well , bring home and flush and wash then put away. a day later i went to start it to show a mate and am back to square one , no spark and the dizzy is getting warm again AND now add when i turn the key to the first ignition click ( one before start ) the engine actually clicks over a bit and will spark once on the ignition coil lead but when you turn it over thers no spark. Then when you turn the key off its now turning the enigine in reverse for about a half second causing a backfire up throught the carby.
surley i couldnt be unlucky enough to have bought a dodgy ignition barrell ?
anyone have any advice i can start looking ?
thanks in advance
so whats it doing ?
thanks in advance
