I have been trying to trouble shoot some issues with my motor. I removed the cover to the terminal block to check the connections for loose or broken wires. In the number 7 spot there was a wire that was loose and missing the screw. It is Gray and Black and said that it goes to the amplifier. I replaced the screw and tightened it back in place. The wire that was disconnected goes to the Safety Circuit Ignition Assembly. From there I am not sure. Is there any reason why this wire would have been disconnected and would it cause a lack of power at WOT? The motor does run without it being in place but will not hit WOT under a load. What does the amplifier do and what does it look like?
Second issue, is tach related. My tachometer is disconnected and the wires were cut at the gauge. On the wiring harness/cluster that comes from the motor to the ignition switch there are several wires that are cut and not connected to anything. Is the wire for the tachometer in this group of wiring and if so which one is it? I read somewhere else on the forum that the wire is gray. There is a gray wire in this group of wires that is cut.
Does anyone have a color coded detailed layout of what each of the wires goes to that is in the wiring harness that is at the ignition switch? I would like to try and get everything reconnected and back in operating condition. At present time I have no gauges what so ever that work. There is a fuel, tach, speedo, and volt gauge in the dash. The fuel gauge I am not worried about because I have a remote tank with a built in sight gauge. I would however like to at the very least have a tach.
I appreciate the help in advance.
