Hi, I have an annoying problem with my 90hp 1998 johnson V4, if anyone can help?
The engine will normally start on the driveway, usual choke action works well, engine settles to idle nicely, I ve in Australia and ambient temperatures are 25C upwards, so no cold starting.
After a road journey to the boat ramp usually 25kms, the engine refuses to run, this usually takes place one in the water and in everybodies way.
The engine turns over correctly, and the engine sounds as though it's started , but dies immediately upon releasing the start key, for the next 20 mins or so this will be the case, Turn the key short rasp fom the engine, bit of smoke then silence.
Removal of spark plugs shows they are wet, but not oily.
At some point the engine wil fire up correctly and run perfectly the rest of the day, never missing a beat, even after an hour of more turned off.
Once the engine does start, it is immediate, without hestitation, which is leading me to believe it is and electrical problem.
When the engine is starting OK, it is faultless for an old unit, plenty of power, no miss fires, even trolling for 2 hours at 2000rpm gives it no dramas, just this issue of starting.
yesterday it wouldn't start as usuall on the water, then ran all day, at all rev's, took a short 65kms trip home, and it wouldn't start again.
any got and clues?? I did verbally threaten to sink the damn thing yesterday, and it started up immediately!
