I have a 2004 2 stroke 15 that I am performing a carb rebuild on (WMC 83). Upon removal of carb I note a seemingly silicone thin gasket on the plenum. And what appears to be a coating in the plenum (looks similar to Teflon) that has a chip missing. I'm trying to determine if the gasket is standard (it has two distinct ridges of uniform elevation & taper). It does not look "DIY". It varies significantly from the gasket included in the rebuild kit, but only in form.
Lastly the chip in the coating gives me some concern. I obviously don't want chips making their way into the cylinders. Is there a fix for this?
Thank you in advance.
