Fuel Pressure out of VST drops to zero after power on cycle.
Fuel Pressure reads 36 PSI during initial key on cycle. As soon as fuel pump stops, 5-10 seconds, VST fuel pressure drops to zero immediately, less than 2 seconds.
Engine starts and runs almost normal, RPM's at idle =750. Cold RPM's vary to 900 RPM. Could this be a leaking injector on a cylinder that is not running below 1600 RPM?
Fuel pressure reads normal, 36 PSI, while engine running. WOT runs at 5400 RPM. Upon engine shut down, raw gas appears to run out of exhaust hub on prop.
Fuel pressure regulator tests okay with vacuum pump applied to regulator vacuum line, at 6-10 inches of vacuum, VST fuel pressure drops to 30 PSI.
My concern is leaking fuel locking up a piston and excessive fuel usage.
Is this indicative of multiple injector failures, due to the rapid pressure drop, or is there another explanation I should check first?
Should I continue to run the engine like this or fix it first?? What steps should I take first to fix this?
Thanks for any help on this one.
