1977 55 evinrude
Adamhcso
Hey All! New to boating world, and have a question some of you might know. I have a 1977 55 evinrude and i replaced the ignition switch because previous owner lost the keys. After doing so, i hooked up a good battery to it to see if it would turn over and all i got was a clicking noise. Any ideas there?? Also when replacing the ignition, a ball bearing came out from inside the throttle lever and i cant figure out where it goes. Any suggestions?? Thanks on advance!!
mark1961
Ensign
Re: 1977 55 evinrude
Provided the battery was actually good.....check all of the connections (battery, solenoid, starter) are in good condition and are clean/tight. If that checks out, you may have a suspect solenoid.
What style of control do you have? pic?
Adamhcso
What kind of control do you mean? Its on a Mon Ark boat and its electric start. I know the starter works because a friend of mine hooked it direct and it engaged. However, like you said it could be the solenoid. Thanks again for all your help!
mark1961
Ensign
The motor control unit at the helm......there are a couple of different styles......yours may look like this......
At a glance, #30 is the only ball bearing i see.
If you have already jumped the solenoid with success then it is the culprit.
Adamhcso
Does anyone know where i would find a diagram or mauuel on line about my 1977 55 Evinrude? The model number is 55773D. Thanks again in advance!
bonz_d
shopevinrude.com for a parts breakdown and parts list.
I was just recently able to find an original manual for my 1975 55hp Johnson on ebay.
Adamhcso
I would really like an original owners manuel too. If anybody knows where to get one, holler at me!
mark1961
Ensign
Worth a look on ebay for both manuals provided you dont mind preloved ones......way cheaper than Mr Cook.
