Antifreeze on cylinders
shanowen1
I accidentally put half a quart of antifreeze in the intake manifold plug. I have removed the plugs and let the antifreeze blow out. I then soaked the cylinders with fogging spray. Is there anything else I should do to minimize the damage?
UncleWillie
Re: Antifreeze on cylinders
As soon as you start it up and warm it up to operating temperature, you should be fine.
Ayuh,.... Welcome Aboard,.... What manifold plug,..??
On What motor,..??
achris
More fish than mountain goat
Yep. Stop using anti-freeze.:facepalm: Just drain the block and leave it empty. AIR DON'T FREEZE..... Just do a search, you'll find quite a few people who 'anti-freeze' their engine's have a cracked block come spring.
thumpar
I would get it running as fast a possible. The heat will burn off any moisture left behind. Then don't use antifreeze. Where I live it is not uncommon to see -20f or below for a spell and I have never used antifreeze in my boat.
ricohman
I am curious to how you did this. Through the carb?
In any event, if you've blown it out it should be safe to start it up and burn the AF up.
JimS123
[/b]
Anti-freeze don't freeze either. As long as you can be assured that all the water came out, you're OK. But if there is a bit left hanging somewhere, the anti-freeze should mix with it and thus mitigate a potential problem.
My Mercruiser owner's manual actually suggests adding anti-freeze after draining the block. Whats up with that?
In my experience, most cracked blocks I saw were done by winterizing dealers that had poor service departments.
UncleWillie
... My Mercruiser owner's manual actually suggests adding anti-freeze after draining the block. Whats up with that? ...
Adding antifreeze to a block that has not been drained just dilutes the antifreeze and you will need to pour twice as much in to flush out the water.
If you are going to use antifreeze;
1. Drain the block.
2. Fill the block with antifreeze using the method of you choice. (Lots of opinions here!)
3. Drain the block again. (Save and Recycle the Antifreeze for use again next year.)
Air doesn't freeze and the residual Antifreeze will protect the remaining low spots if any.
GasCan II
How about the anti-corrosion benifets from the pink R.V. antifreeze when the block is properly filled ?
Ayuh,.... Whatever trips yer trigger,...
Corrosion in a drained motor is immeasurable...
Any corrosion ya see in a motor used in freshwater, happens durin' it's use, not durin' the lay-up period...
UncleWillie
How about the anti-corrosion benefits from the pink R.V. antifreeze when the block is properly filled ?
Even drained, the Propylene Glycol (PG) is still coating all the metal in the block.
PG is essentially a water soluble Oil.
Dip a pair of old pliers in some PG and let it lie around for a few months; It will still be oily.
The water in the antifreeze will evaporate, but the PG will hang around for many more months that you have patients for.
I peeked under the boat cover last weekend and a few drops of PG that I apparently spilled on the swim platform two Months ago were still wet and oily.
