I have a 93 Bayliner classic 18.5 footer with the Mercruiser 3.0 and the Alpha One outdrive.
Sometimes I have an issue while on the water. This doesn't occur all the time and when it does it usually doesn't last long.
The best way I can describe it would be to compare it to drive your car/truck on icy roads and you lose traction. The motor revs up and the car shakes but you don't go faster.
My boat does the same thing every now and then. I can run all day on the lake and then on another day it will happen. If I just back off the throttle and then increase the power slowly it will go away after a bit. Anyone?
