hello once again guys....
i have a 1988 25SG hp two stroke. rebuilt carbs, new gas tank, lines, filter, diaphragm.
was out in it 2 weeks ago and although it ran like a champ for an hour, lately it has been a little tough to start. use to start on 1-2 pulls, and idle right away without the choke..... when out 2 weeks ago it would take about 10 pulls to get it started, but once started it idled and ran like a champ.
anyhow, decided to start it today and let it run, but it took about 50 pulls to get it started. once started its running like a dog.
did a compression check in neutral with choke on and second plug out, and both cylinder are 110psi.
fired it up again, after about 50 pulls, and was giving it slight throttle, and wanted to check for spark, by pulling one plug wire at a time. pulled the top wire first, with an insulated pair of channel locks, and WOW, it still shocked me through the insulated pliers, and stopped running immediately. ok, that coil/plug seems to be working correctly..
started it back up and did the same thing, pulling the bottom plug wire.. this time it did NOT change anything in how it was running, and although i didnt get shocked like when pulling the top wire, i could faintly hear spark jumping from the wire to plug end when reinstalling it, but it did NOT change how it ran. left it off and it ran the same as if it was on.
could i have a bad coil ? can i swap the coils and see if it does it in reverse, guaranteeing a bad coil ?
any help would be greatly appreciated.... this engine has been killing me since i bought it in September...
thanks guys...
thanks guys...
