pscrabber59
- Apr 12, 2010
- 246
I have a 73'-76" Johnson 20-25hp motor that came off a duck boat i bought a few months ago. Compression is 100 and 95psi, cleaned the plugs and it started and runs fine at idle, but when i shift into gear it dies out. Another problem is when i get ready to start it I pull the choke knob out gas/mix leaks from the carb. bowl? I don't plan on keeping this ob but i want to fix the issues if i can and if the parts are cheap enough so i can sell it.
