Bravo II Trim Ram rebuilt
pernicia
I need help determining the correct kit to rebuild the trim cylinders. Is it hard to do?
I have a Bravo II serial # 0k096574
Engine is 5.7LX 0k009206
Thanks in advance,
Re: Bravo II Trim Ram rebuilt
Do I need the Overhaul kit or the seal kit?
Ayuh,... Welcome Aboard,.... It's hard to say what yer gonna need,...
Ya haven't told Us what's Wrong...
Don S
I would guess that depends on why you are rebuilding it. If it's just a leak, I would guess the seal kit would be enough, unless the rod is damaged or the end cap is corroded.
The overhaul kit includes includes parts 1 thru 19, the seal kit only 12 thru 19.
pernicia
Guys, thanks for the response.
How can I tell if there is corrosion, just simply looking at the cylinder cap?
The trim is very hard for drive to go up and down, almost not moving.
Don S
Yes. Are you sure the pump isn't the problem? Maybe low pressure? Does the oil in the reservoir look milky?
MarkSee
Are you seeing leakage as Don mentioned or is it just hardly moving but not leaking?
When my Maxum seemed to start struggling a bit and making some noise going up and down, I just cleaned the exposure ram really good then coated it with Grease and worked it a few times, that seemed to solve the issue. Maybe your is worse.
In addition to the parts/kit Don mentioned, you'll either need to buy, make or borrow a tool to take the end cap off.
Mark
pernicia
I don't see a leak, it's hardly moving. The mechanic worked on the drive last week, and I asked him and he said is the seals inside.
