Wareagle84
- Dec 10, 2012
- 7
Just got first boat and it's a project boat for fun. Boat has a 1996 Johnson 48hp (previous owner replaced water pump, only thing replaced other than routine maintenance). Motor runs fine, it idles a little rough and smokes a bit. The problem I am having is a noise motor makes when I shift from neutral into forward the motor makes a pinging noise. Almost sounds as if something is touching the flywheel for a second when I put into gear. Working on this alone so I haven't been able to visually verify yet. Any suggestions as to where I should start my search? Also any suggestions to recommended maintenance motor could use as it sat for a couple months (other than plugs and gear oil changes those already). Thanks for all suggestions!
