Hi all, just bought a boat with a j175txcua , 1987 johnson 175 v6 crossflow. The previous owner removed the vro completely and wired a cheap automotive fuel pump that is not working properly.. I want to install omc dual pump setup used in the 76-83. Does anyone know what part #s I need for the upper and lower fuel pumps. Is there any difference in the upper and lower fuel pump? I was told the older fuel pumps would work on this motor. Thanks on advance for your replies...
