Well, this is only to start. I'm looking to up the horsepower on my general purpose (cruising and water skiing) Regal 2100LSR to 260-270 through 10.75:1 compression, a Edelbrock 1409 carb, and a mild Comp cam and I was wondering a few things.
I wouldn't mind taking a little weight out of the engine, any ideas sans aluminum heads? There doesn't seem to be much margin in the crankshaft, how about a slightly lighter flywheel? The exhaust manifolds are crazy heavy, and the aftermarket doesn't cater the the V6's much, but that seems like an easy target.
How many rpms can the stock rods reliably turn? What should I use to get 5250-5500 rpm?
If I put in a Comp 266AHR or 270HR, how can I get the ignition curve to compensate, especially on the low end where the bigger cam's lower vacuum could cause erroneous readings?
Do any of you have good or bad experience with any of the aftermarket pistons? I need to order those soon to keep my machinist busy.
When I measured the ring gaps, I was getting around .024 top, .030 second. That doesn't seem very worn to me, is it? I was getting 22-37% leakdown and 115-125 psi compression on the cylinders, hence the rebuild.
I've only rebuilt Japanese 4 bangers up to now, mostly motorcycles. I'm impressed with the overall design of the Chevy, which is something I never thought I would say!
Thank you to all who reply with constructive feedback.
Rick
Rick
