I have a Baja with a Merc 454/Bravo 1 out drive.
I'm in the process of winterizing my motor/changing the oil.
I have the boat in my shop and it always gets messy if I plug water in while running it in the shop.
I've done this a couple of times without problem so far. But wondering if there is anything that I don't know about that I might be damaging.
I've been running the motor with no water by taking off the belt so no water enters the engine. If the raw water pump is not turning (damaging the impeller) and don't let the boat idle more than 10-15 minutes, is there anything else I could be damaging? I know the Alpha drives have the raw water pump in the out drive, but I know that is not the case for the bravo. I'm only doing this to let the oil get hot to pump it out.
anyone think of any damage I might be doing? or is this a safe practice?
