Biminibrad
- Dec 8, 2012
- 6
Hello, all, I am ready to kill this thing. I have a 2008 4.3 mercuiser raw water cooled boat with 20 hours on it nada flush pro installed. The boat sat for a while and I have done the following.
1. Replaced impeller
2.after running on ears it over heats.
3. Water pours out of one side on the transom out side the boat, but a steady trickle out of the other.
4. Took out plug on bottom of circulation pump and ran it on the flush housenhookedmto transom, bunch of black stuff came out.
5.removed thermostat
6. Removed circ. pump, flushed, and flushed passages on both sides of block where circ pump mates to.
7. Have run engine on both flush hose and muffs, still overheats
8.disconnected all hoses and flushed and checked for obstruction
9. Disconnected circ hose at thermostat, started engine and verified water flow hose at thermostat
It seems like one side or the other over heats, like water is not being evenly distributed. I checked the ball things that got risers,they move freely. Any help appreciated.
