Re: mercury 75 hp starter problems
Assuming that the threads in the nut and the end of the armature shaft are in good shape, and assuming that you're tightening down the nut enough to start with, I'd try some
blue loctite, after thoroughly cleaning the threads of any oil or grease. If that doesn't do it, then I'd go for the
red.
Yo, and if that didn't work, I have MIG over in the corner . . .
As for the any idea question, I do wonder if you're tightening the nut enough, or whetehr you've omitted a lockwasher or perhaps substituted a nut d'ordinaire for a locking nut. BTW, the MIG suggestion isn't entirely in jest. If used judiciously, it's not irreversible. If used rashly, when you eventually need to rebuild the starter (if you ever do) a new starter ain't much more than a rebuilt one anyway.
