Cummins 903 smoking
charliebabb
Hey guys, Im having a problem with my twin 903 Cummins in my 1976 42' Hatteras. The starboard engine barely spits out any smoke where as the port smokes a lot. I replaced the turbo on the port motor and it didn't help. Could it be injectors?
Thanks for the help in advance.
sean mathews
Re: Cummins 903 smoking
black generally indicates an excess of fuel. could be one or multiple injectors have broken tips or the fuel pump is out of wack. i suggest talking to a diesel injection shop
QC
Losing an injector tip will result in a much bigger problem than black smoke ;)
rthomas
Does it smoke at all throttle/load positions? If thats the case and it seems to run ok I would look at injection timing, retarded timing will make smoke and high EGT, another symptom of this can be if the motor is a little quieter or different sounding than the other one. If you had a bad injector you would have a few other symptoms like missing or a knocking sound.
My boat is a gasser but my pulling rig is an 02' Cummins......all those replies sound spot on.
