Bravo 2 noise
jreau
I know it's hard to diagnose a noise without hearing it but I'll ask anyway. I have a noise that seems to be coming from the outdrive that started shortly before haul out. It's kind of a rattling, clanging type noise at low rpm (700 - 1500). It does not change when I turn hard in either direction. I pull the drive every year for inspection and put maybe 35 hours a year on it. I change the lube every fall with the recommended quicksilver high performance lube and it looks like new when I drain it. I always drain it into a very clean pan so I can check for metal shavings and have never found anything in the old oil.
I read where a gimbal bearing noise would be effected with a hard turn and like I said I don't hear any difference going straight or turning. Any help would be appreciated
Re: Bravo 2 noise
Ayuh,... Welcome Aboard,.... I assume that this year was like all the past years, 'n the drained oil was clean, 'n clear,..??
Does shiftin' into, or outa gear change the noise,..??
GasCan II
Re: Bravo 2 noise
Are you sure the noise is in the drive? Just a guess but it could be your exhaust shutters (flappers), try listening inside the boat after the bend in the exhaust after the risers.
Good Luck !
jreau
Re: Bravo 2 noise
Gascan I'm not sure what you mean by "exhaust shutters (flappers)". My exhaust comes out underwater through the drive.
Re: Bravo 2 noise
Ayuh,.... Inside the hull, there's exhaust Manifolds, then Risers, then cast elbows, then the Y-pipe which bolts to the transom housin'....
Inside the Y-pipe, at the very top, lives the exhaust Shutters, which are to block any back-wash of water into the motor...
If the rubber gets burnt off, they'll rattle at idle,...
Good call Gas Can...
