homelite
- Aug 13, 2002
- 156
I just bought the above. It has 300 hrs on it. I never had an inboard. I am a certified auto technician so I just need pointed in the right direction.
First of all, there is a raw water 3/8" hose feeding the seals. I assume to cool them. Questions are:
How to get in there? I'm mid size. 5'8" 180lbs. I assume....remove both inside exhaust manifolds so i can get down under the engines??? Even that will be very tight!
Then comes how to do the job so because once I'm done it won't be easy to check to see if it's fixed.
How much water is normal? If any?
How tight should it be?
Thanks and I look forward to any help!
