1979 85 hp johnson water in lower unit
wayneo99
getting oil in lower unit.
replace the washers on the vent and fill plugs, oil still came out milky.
removed prop, water pump so I could see the seals and pressurized it to 15lbs.
it held the 15 psi all nite long. sprayed prop seals, drive shaft and shift rod with soapy water while moving them and saw no bubbles.
this thing bench tests fine.
a friend who is a old certified omc tech from way back says since its so old there may be some seal leakage under load as the case itself may be worn and the tolerances out of spec.
he advised me to change the seal and shift rod oring but not to mess with the prop seal as it may not seal correctly once its taken apart.
he says to change the oil in the middle of the season and it should be fine.
I have known this guy for 25 yrs and thats all he works on is johnyrudes.
any thoughts?
i want it to stop sucking in water
he say buy a new motor lol...
wayneo99
Re: 1979 85 hp johnson water in lower unit
bueller? bueller?
wayneo99
FYI
pressure test was normal as it held 15 psi over night.
I did a vaccum test and it could not hold 10in Hg and instantly started sucking in the windex i sprayed on the drive shaft seal for the pressure test.
i used a basic break bleeder vaccum tool from harbor freight.
going to order a new drive shaft seal housing with a new seal in it.
Roberthill
Had a old Evinrude that could not keep water out of lower unit , took a fill plug and drilled a hole in it and welded a grease fitting on it and filled the lower unit with grease , it worked for years . I learned this '"TRICK" from a very old machinist back in the 50's .
