Help with 1960 Johnson 18hp Seahorse
Zapit2um
Needing some help diagnosing a problem with my motor. As the title says I have a 1960 Johnson 18hp seahorse.. It was running like a champ and was getting about 18 to 19mph out of it then it seemed to lose a little bit of power, I checked the speed and I was down to about 14 to 15 mph. It ran like this for about 5 minutes then lost almost all the power, was doen to 5mph at best. I tried adjusting the high speed idle but it didn't seem to help. When I have it in neutral with the throttle wide open it seems to be running fine, by that I mean the rpms seem to be there, it's screamin. But when I put in gear and throttle it up.. nothing 3 to 4mph at best. I cleaned the plugs and regapped them tried new gas, nothing seems to help.
kbait
Re: Help with 1960 Johnson 18hp Seahorse
If you pull the recoil medium speed, and you feel a good 'whoomp, whoomp', you likely have adequate compression for both cylinders. Check spark, and be certain that you're getting 1/4" blue bolt from both leads. If so, install new J6C plugs gapped to .030" and try again. If it's only firing on one cylinder, it'll seem to run just fine in neutral, but only go about 1/3 speed. If it still runs the same w/verified spark and new plugs.. check compression w/gauge to be sure it's good, and pull and clean carb.
Don't over-rev your motor in neutral, or you may suddenly have a new top-speed of zero.
Good luck!
steelespike
A quick check for spark pull one plug wire at a time and see if it will run.
if it won't run on one of the cylinders could be lack of spark.
If the coils haven't been replaced recently they both are suspect.
HighTrim
Is this motor new to you, or have you had it for a while?
As stated, is this an original igntion, or have you updated it?
If the coils are original, they are 100% shot.
Zapit2um
Motor is new to me. Here's what I did. I fired it up let it run for a minute then disconnected the top spark plug wire and it died. I hooked the wire back up re-started it and unhooked the lower spark plug wire and it kept running. I then switched the plugs around, just to check them, and had the same results as before. I'm guessing the bottom cylinder isn't getting fire.
Thoughts?
HighTrim
Pull the flywheel, time to go over the ignition. If the coils are cracked and deteriorated, they are original and need replacing.
Dress and clean the points with acetone, and set at 020. Condensors should be checked as well. If plug wire is original, I would replace it when changing coils.
If ignition has been updated, may be a matter of cleaning and regapping points, or may be a faulty connection in plug boot, something simple.
freddyray21
it's dropped a cylinder either a coil or a condenser is bad
Zapit2um
I've taken the starter rope off and have removed the nut to the flywheel. Should the flywheel just pull right off or is there something else I need to do? Do I need a flywheel puller?
HighTrim
You need a harmonic balancer puller. Available cheap at harbour freight or princess auto depending if youre in US or Canada.
There will be an inspection window, removed by taking out the screws holding it onto the flywheel to know what you are dealing with.
Get grade 8 bolts to replace the ones that come with it, they will be junk and break. There is actually a good write up in the Faqs to save us some typing.
EDIT here it is
http://forums.iboats.com/engine-fre...-change-coils-set-points-old-omcs-294072.html
Zapit2um
Pulled the inspection window and from what I can see everything looks brand new. Will get a puller tomorrow and yank off the flywheel.
HighTrim
Usually, and I stress usually, regarding the Universal Ignition, you can visually tell if it is ok. If it has been updated, it is likely good.
Now you can test the continuity of the coil, but unless you have a Mercotronic or Stevens tester, which you likely dont, you wont be able to test it with a load on it.
The following is a better site for a description of testing the coils continuity.
Testing an Outboard Coil with a Multimeter using an ignition coil from the Johnson H or T
1946Zephyr
Do the coil wires look new? Sometimes coils get replaced by previous owners, but the original wires are still in use. It's best to trim off 3/8" off the coil end and 1/4" of the spark plug end, if the original wires are put back in service. You can also swap condensors to see if the spark goes to the opposite cylinder. If so, you may only need condensors. Also check that your points are thoroughly cleaned and re-gapped.
Zapit2um
I rented a puller from Autozone so I will be pulling the flywheel off tonight. One question, do I use the holes that hold the inspection cover in place to attach the bolts for the puller?
When looking throught the inspection window it looks like I have one red coil (looks new) and one black coil. I'm wondering if the guy I got it from only replaced one of the coils. That's where I am going to start anyway.
HighTrim
I have never seen a new red coil. Post a pic of it if you can. The newest red coil that I can think of is from '62, they were possibly aftermarket.
Yes, those are the holes that you use. Thread the bolts in 7/16", no more no less. Mark the threads with a sharpie so you know how far to thread the bolts in. Stack a few washers on each bolt. I would leave the nut on flush with the top of the crank to protect the threads, and to keep the flywheel from jumping up in the air when she pops off. If you rap on the center puller bolt, lift UP on the flywheel first.
let us know how it goes.
Zapit2um
I sure will hightrim. I could be wrong about it being the coil, i just seen a red item and a black item through the inspection window. I will also post pics once the flywheel is removed.
Thanks for all the information, this forum is great!
HighTrim
What you may be looking at is the condensor.
The older ones had red tops, the new condensors have black tops.
tomhath
Master Chief Petty Officer
If the contact surfaces of the points look black/burned you might get a spark by cleaning them, but that's the sign of a bad condenser. It's supposed to protect the points from arcing when they open (and they are cheap to replace).
Zapit2um
Here are the pics. The red coil seems to be older than the black coil.
freddyray21
the red coil (which fires the lower cylinder) looks like it has a worn spot on top which it should not have.
